Yai
Hi,
I have a 2012 N.American(Canada) Golf TDI Highline, that came with Halogen, in stock trim. Ended up retrofitting Bi-Xenon with LED DRLs from a 2012 GTI. I found out, the GTI was using the same midline CECM, as my TDI: 1K0937086P. My TDI software version is 0657, not sure what the GTI was.
My low beams/Xenons work, along the LED DRLs, and the high beam function. My issue is the LED DRLs are always simultaneously on, with the low beams/xenons. Ideally, it would be better to have the DRLs on(by themselves) during the day, so I’m not burning through xenon bulbs, as was a pain for to change the xenon bulbs! I’ve tried various codes on Byte 18 (currently using 22 with no errors, and all lights working). I got a euro switch, and played around with some coding, via OBD eleven long coding. I have the oem LED tails w/o rear fogs, and no bulb errors with the current coding(see below).
On my CECM coding(below), for the DRL/Xenon settings that I came across, I have the following bits checked/unchecked.
Byte 9 - Manual activation/deactivation for DRL suppressed = Active-checked
Byte 11 - DRLs /Active-checked
-Permanent Running light via low beam = unchecked
***-Bit 6=Checked (no description so not sure what this is)
Byte 14 - Bi-xenons with shutter installed =Active-checked
Byte 15 - DRLs with separate lights = Active-checked
-DRLs adaption MFA+ = Active-checked
Byte 17 - Bixenon additional high beam (installed) = checked
Byte 18 - hex=22
Byte 24 - Hex =E4
Byte 25 - DRL LED brightness =Full
-High beam via shutter Installed =checked/active
Byte 26 - DRL only with assistance driving light =unchecked
Byte 27- LED DRL module for parking light and DRL =Installed/checked
Long Code: 6F180A1B90272AC400880041400009EC48862280524D8520E48620040040
Any suggestions I could try, as I been searching everywhere, also tinkered with so many of the DRL settings, and byte 18. One thing I didn’t try, as I just read, was to give the MFD a reset to factory. I heard, some settings may not take effect, even when coded properly, if the factory reset on MFD, wasn’t done? But this person swapped out a new BCM, when they suggested to reset MFD.
Also, what should byte 18 be? I figure I should keep that setting, as a starting point, if bit 22 is incorrect?
Thanks,
Ron
Byte 18 - hex=22
Byte 24 - Hex =E4
Thanks,
Ron
