Sevenjays
I did as much research on the forum as I could and tried all the troubleshooting tips I could, but I haven't found anything yet.
The problem: I was running errands up town, came out from the store, started the car and drove to the parking lot exit and the car died as I was approaching the stop sign. I tried to restart, but it only cranks over. I pushed it back to a parking space and started trying to figure out what went wrong.
Things I've tried. I checked the starter and alternator at the auto parts store, both are good. battery is just over a year old and seems to be okay, but I have noticed the car cranks slow often so I might need to get the battery load tested.
Pulling the input line off the tandem pump and running the tank pump produces fuel, but it seems slow, the pressure was only 3.5 psi when plugged off with the gauge. It should still start though, shouldn't it? I did change the filter with no change in symptoms.
Timing belt is good.
Glow plug light and check engine come on before cranking, the battery light stays on while cranking, can't remember if this is normal or not.
What next?
What next?
