dhangejr
This is what started it all…diff blew up
And Suddenly this seemed like A good idea
It was ability to get out in traffic from a stop is GREATLY increased with that there LSD! (I got a 30 day Facebook ban for saying LSD regarding that part)
anyway next I built some headlights
then clutch was slipping which is really upsetting because it is a stage 2 daily by SB.
Turns out the tandem pump was leaking fuel in the trans inspection port causing random slipping. The leaking tandem pump was probably a result of the failed lift pump.
at the same time I noticed my cam shaft was ****…lame!!!
So It was around Christmas and I was given a stage 2 cam as a free upgrade.
after having the camshaft specked out at Delta cams in Tacoma Washington I determine it’s worth installing and this happens
TDI PD cam and timing belt diy
www.myturbodiesel.com
