brodiakbear
So I am a first time ever tdi owner! Just picked up a 2014 Jetta tdi 6 speed manual! I've had it for 2 days now and I'm absolutely in love lol. Like the title said, What's the best cruising speed I'm order to achieve high MPG.
55mph would yield the best mpg and not get you run over on the highway, try not to brake a lot, and accelerate by shifting at about 2500rpm to 3g, you should get in the high 40's doing this, if not more...So I am a first time ever tdi owner! Just picked up a 2014 Jetta tdi 6 speed manual! I've had it for 2 days now and I'm absolutely in love lol. Like the title said, What's the best cruising speed I'm order to achieve high MPG.
Bear in mind that your mpg numbers will steadily improve (slightly anyway) as the engine breaks in, and diesels take tens of thousands of miles to fully break in.So I am a first time ever tdi owner! Just picked up a 2014 Jetta tdi 6 speed manual! I've had it for 2 days now and I'm absolutely in love lol. Like the title said, What's the best cruising speed I'm order to achieve high MPG.
You meant uphill, right?In cruse control the DSG will shift from six to five on long down hill to maintain set speed. Try to slightly increase speed on down hill or take cruse control off.
I agree. And for those who are really gaming the mpg thing, constant throttle (or fuel delivery, I guess technically diesels have no throttle) - letting your speed drop - is generally the cheapest way to climb that hill (assuming you hit it with enough speed to avoid downshifting - which is what I think you were saying).For large hills I've found that a bit of rpms helps keep the engine in a more optimal power setting. Trying to attack a large hill at 55mph will require lots of boost and the mpg display will dip way down. But at the speed limit or slightly above I can cruise up the hill with very little boost and mpg stays pretty high.
The DSG will downshift to maintain the set speed going uphill or downhill. It will also get VERY aggressive on the downshift when you combine downhill and braking for the light at the bottom.You meant uphill, right?
If your DSG is downshifting, going downhill, while maintaining steady speed, then there is something wrong with your tranny (which I doubt).The DSG will downshift to maintain the set speed going uphill or downhill. It will also get VERY aggressive on the downshift when you combine downhill and braking for the light at the bottom.
You may be feeling engine braking when coasting downhill and you are mistaking that for downshifting - if you're accustomed to slushbox ATs the DSG feels more like a MT in that regard. The DSG ALWAYS downshifts though every gear as you coast/brake to a stop - nothing to do with hills. I think we were mainly talking about steady-state hwy cruising.
You can always confirm by nudging your shift lever momentarily into tiptronic mode, and your MFD will display the current gear you're in (without causing a manual shift).
Ok, now I understand what you are saying, but you are losing some of the payback you should be getting on the downhill side (we're still on-topic btw). I tend to toggle CC off when climbing steep hills, keep the go pedal steady and let it bleed off some speed, coast downhill (CC still OFF) and don't resume it till I approach the bottom of the hill.It will downshift from 6 to 5, on it's own, on a steep(ish) hill, where normal engine braking does not hold the vehicle back and it accelerates beyond the set speed.
If I had to guess, I'd say that most hypermilers are, by definition, very conscious of what they are doing - and probably want to stay out of your way. Most of the people I see holding up traffic in the left lane just seem oblivious in a general sort of way. I doubt there's any direct correlation between hypermiling, and lacking consideration for the people they share the road with....if you're going to go slow to save fuel, do it in the RIGHT lane. This boy racer is getting militant.
This.Ok, now I understand what you are saying, but you are losing some of the payback you should be getting on the downhill side (we're still on-topic btw). I tend to toggle CC off when climbing steep hills, keep the go pedal steady and let it bleed off some speed, coast downhill (CC still OFF) and don't resume it till I approach the bottom of the hill.
If the downhill is steep enough to maintain speed or even gain a little I just let it go, if not I bump it into neutral if it's a long hill (again, this would be straight up hwy with no traffic lights). The only time I want a downshift to engine brake (not rolling to a stop) is in the mountains - that's when tiptronic comes in really handy (the Golf's flappy paddles are perfect for that).
Also, if you're hypermiling you HAVE to learn to coexist rather closely with big-rig drivers, and they take a VERY dim view of anyone who interferes with their momentum (and anyone who's ever driven a truck with a big payload understands why).
Oh shoot, I mean I drive slow in the right lane in my VW going to and from work. I drive truck locally and am paid hourly, and I dont hypermile in my truck. Lmao.Did you mean to say you just drive slow in the LEFT lane? And, I'm guessing you're not being paid by the mile if you go only 50 when you can. Is that correct? Sure, getting great mpg's is good but there's always the value of time too.
I also have a Jeep GC CRDMy TDI is a manual 6, almost an apples-to-oranges ocmparison, but I have learned two things:
1) below 1800 RPM I'm losing efficiency (the engine reaches max torque @ about 1800)
2) when I keep it in gear, and lift off the accelerator to coast downhill, the fuel stops flowing. This results in MPG's above 99 (off the scale of the computer).
I get best MPG @ 58 MPH - have twice recorded 52.
I took a 600 mile trip averaging 75MPH (80 MPH limit) and got 39, with the car fully loaded.
I also have a Jeep w/3L V6 CRD - it hits max torque @ 1650 RPM, and has a 5 spd automatic w/3:73 rear gear. It's most efficient speed is 50MPH, where it can get up to 30MPG. Driving 75MPH in that car yields 23 MPG.
Tire pressure, humidity, air temp, road surface, and a whole slew of other factors all play a role in your real world results.
