I Broke the terminal bolt on my 2011 SportWagen TDI, has anyone found them in the stores or online? I can't seem to find a terminal bolt small enough and I see these T bolts online and am not sure they will work.
You mean the starter battery terminal bolt that's supposed to keep the nut from backing off completely? I can't find this battery terminal in ETKA (in the usual places), only the wire set for positive (1K0971228M) and negative (5N0971235A) terminals. I haven't looked at these since mid Dec; I'm thinking the terminal nut is 10 mm (though not a standard bit of SS hardware, as I recall). --g
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
