JBjunior
So, 2003 Jetta with a brand new alternator and multiple batteries with the same results. Drove it 300+ miles today and it drained two batteries even though the alternator appears to be working properly.
ABS light and Air Bag light came on a couple of times intermittently. Ran it on VCDS and this is what I got. I am suspecting a ground/short, but hopefully there is something quick I can check.
Any help is greatly appreciated.
Codes I have are:
Engine
18057 - Powertrain Data Bus
P1649 - 35-00 - Missing Message from ABS Controller
ABS Brakes
01276 - ABS Hydraulic Pump (V64)
012 Electrical Fault in Circuit - Intermittent
00668 - Supply Voltage Terminal 30
008 - Implausible Signal - Intermittent
Airbags
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Steering wheel
00926 - Terminal 30
Instruments
01316 - ABS Control Module
49-10 - No Communications - Intermittent
CAN Gateway
Central Conv.
00931 - Locking Module for Central Locking; Rear Right (F223)
54-10 - Incorrectly Equipped - Intermittent
01359 - Internal Central Locking Switch; Passenger Side (E198)
27-10 Implausible Signal - Intermittent
Radio
07-10 Signal too Low - Intermittent
00856 - Radio Antenna
36-00 - Open Circuit
01305 - Databus for Infotainment
37-10 - Faulty - Intermittent
Codes I have are:
Engine
ABS Brakes
Airbags
Steering wheel
00926 - Terminal 30
Instruments
CAN Gateway
Central Conv.
Radio
