DieselDavid
Well, I finally made a mistake at the gas station the last time I filled up my TDI with diesel. It was a name brand station. I've bought diesel at other stations with the same brand name, and this was my first - and last time - at this specific station with the same brand name. After pouring some diesel fuel additive into my car's tank and swiping my credit card at the pump, I removed the pump's nozzle to discover the diesel nozzle was too large for my passenger car! I checked the other diesel pump at this station and it too had the large-sized nozzle for trucks. I took a chance and tried to refuel anyway. Big mistake. I had to carefully hold the pump's handle near my car's opening for pump nozzles, gently squeeze the pump's handle to trickle the diesel fuel into my car's tank to avoid splashing, and it took me 35 minutes to refuel my car with about 14 gallons of diesel. Halfway through my hands began cramping.
I have complaints about the attendants at this station. None of the them knew what I was talking about with respect to the incompatible size of the diesel pump nozzle and my car's fuel tank opening. After pumping slightly more than 1 gallon the pump shut off and would not re-accept my credit card, so I had to go inside the store area for help. The attendant insisted upon holding my credit card "hostage" while I refueled. (At this point I should have given up and driven to another station.) As with most other stations, the cetane rating of the diesel fuel was not labeled at the pump, and none of the attendants could tell me the cetane rating of their diesel fuel.
I shared all of this with the gasoline/diesel company by way of an online survey at their web site. Probably nothing will result from this, but at least they are aware of the problem that I experienced, probably other customers experienced, and probably other customers will experience in the future if nothing changes.
Now I have suggestions for all gasoline/diesel stations:
- Set up diesel pumps with both a large-sized nozzle for trucks and a normal-sized nozzle for passenger cars.
- Have at least one diesel pump with each nozzle size.
- Clearly label the diesel pumps so customers know which nozzle size is in use at each pump.
- Label the cetane rating at the pump.
- Educate the attendants on diesel fuel, diesel fuel pumps, diesel cetane ratings, etc.
- Keep some sort of adapter handy for cases when customers with passenger cars need to buy diesel fuel and only the diesel pump(s) with large-sized nozzles are available.
