vixentd
Just started with a loud banging sound as the window went up for the final 1/4 inch. Took the door panel off hoping maybe a loose bolt but they were all tight. After playing with the switch up and down to see if I can determine problem, it now goes up and stops but keeps on making a banging sound until the window switch is no longer pressed.n I notice also that the inside of the metal door panel at the bottom is pushed up when the window goes fully up. It buckles out a bit.
It also seems to be sloppy when the window is halfway down and you press the window switch up or down. The motor works but the window moves up jerky.
Years ago on the passenger side I replaced a regulator because it was worn out and the window was going up crooked. But the window goes up straight.
Is it probably the gears on the top of the regulator that get stripped or worn.
- If so has anybody had success in tig welding and refiling the gear?
Any input is welcome
1996 Passat
1996 Passat
