86turbodsl
Hello, as I noted in another thread over at the B4 General forum, recently our B4 Wagon suffered a catastrophic turbo failure and runaway that lunched the engine. I'm still in the process of tearing the motor down to see how bad it is, but judging by the runaway and how much oil I pulled out of the intake tract, that it's going to need a rebuild at minimum. The turbo is completely lunched. So, while I have the engine out, I'm doing basically all the hipo mods I've known about with an eye for as much power, least smoke within reason, and longevity I can get. Car has 220K on it, and it needs the once over.
The basic block I wanted to do as much flow related work on it as possible. Some key mods I've been looking at:
Pistons w/ceramic coating
Gapless rings (most likely total seal)
Anti-friction coatings
Some sort of larger turbo. I'd realistically like to
see 25 psi or therabouts, with minimal smoke, and as much
boost as I can get at low rpms.
I'd heard that older 1.6/1.9 IDI manifolds fit this engine, is that true? And if yes, what turbos did IDI's come with?
Ideally, I'd like a common T3 on it, wastegated, so that parts to rebuild the turbo if needed, or change A/R housings are easy to come by.
Any insight on this? What will fit behind the engine?
I'm planning on some larger nozzles, such as 520's or even the 764's, if I can get enough boost to burn the fuel.
The lack of EGR is a plus (non-emission state/off road)
Rocketchip custom eeprom is a given. I need to be able to add fuel to match all the new boost.
I have all the materials for a full 2.5" T304 exhaust ready.
Anything I'm missing?
This is the wife's car, she's a bit of a hot rodder, and has complained of the lack of power in this car since we bought it. My intent is to totally surprise her with a rocketship when I'm done.
