Vince Waldon
Lugging a double-bass around all day the default rear hatch behaviour on my 2006 Jetta Wagen is really starting to wear thin.
Would like to re-code the CCM so that the hatch unlocks the same way the rest of the doors unlock.
The two approaches seem to be:
1) run a jumper with diode between the door module signal and the rear hatch signal, per Pencilnck:
http://4130-products.com/step/hatch/index.htm
2) reprogram the CCM using VDS-Pro, an old laptop with a COM1 port running DOS, and a serial port OBD2 adapter:
http://forums.tdiclub.com/showthread.php?t=161339
I've done the jumper and it works fine, except that because the hatch thinks it's unlocked every time the doors are unlocked the car alarm won't arm unless you physically open the rear hatch and then close it again.
Thus I'm investigating the CCM reprogramming option... EXCEPT I have to track down an old laptop with an actual 9-pin serial port and a eBay-special serial port dongle... probably 50-100 bucks worth of stuff, assuming I can find the right serial port adapter in the sea of eBay offerings.
Hence my question: has anyone ever found a more modern way to talk to the CCM? VCDS won't, Vag-Tacho won't.
