I tried it
I have PD140 16V so I don't know how pertinent this is to 1.9 engines, but there are some interesting results to be had.
I tried both advancing and retarding both cams.
Advancing resulted into great response off idle, stong low end power and noticeably decreased power from 3000rpm up.
BC showed much lower fuel consumption, but in reality it stayed same as before.
Retarding cam reduced power in lower revs, throttle response was more dull, but from 3000rpm up it went like cut snake and kept pulling beyond 4000rpm.
With stock timing engine just suddenly lost all power at 4000rpm and refused to rev any further.
BC showed much higher fuel consumption, but calculation at the pump revealed that it was acually lower by about 0,2l/100km.
BUT - after I started adding diesel additive fuel consumption decreased by another 0,5l/100km which is total of 0,7l/100km lower when compared with stock timing.
And the same fuel additive did absolutely nothing with stock timing
I SWEAR I'M NOT MAKING THIS UP. I absolutely don't understand what happened there, but I'm definitely not complaining
Btw, my mechanic almost murdered me after he spent considerable amount of time trying to "fix" crankshaft to camshaft pulleys when replacing my camelt only to find out it's impossible because I have retarded cams like half a tooth in relation to crankshaft compared to "proper" timing
So that is my experience tinkering with cam timing. Hope I won't be stoned to death for this post
