Well since this has been a slow going overhaul, I'll fill you guys in on what's happened.
I went to an "Automotive Electronics" shop here in town and asked them about the bearings. The guy says he can sell me "alternator bearings" in sizes 6203 and 6303 (the correct and very common sizes for this Bosch alternator). I asked to confirm they have a high enough speed rating, to which he replied "Well, they're 'alternator bearings', so yeah." I figured for $15 total, it was worth the shot. They were an off-brand that I did not recognize, so I did the research on them.
I have found that no matter what brand, the bigger bearing has the slower speed rating. That makes since, of course, due to more weight and whatnot. Well, the 6303 bearing that he gave me has a max rpm limit of 11,000 rpm. Not really enough when you take into consideration the pulley size differences and the red-line on the 1Z. The way I calculated, I would need a bearing that could withstand 15,900 rpm when the engine is at red-line. *Disclaimer: If my engine
ever sees red-line, it would only be briefly... but I do like the peace of mind of knowing the components can withstand it.
There is a place called "Bearing HQ" about a half an hour from me that I decided to check out. They're not an automotive shop or anything, they just manufacture/sell bearings of all types. I asked them the same question; "Is there a difference between bearings used in alternators and regular sealed bearings?". To his knowledge, no, there isn't. So he went and grabbed a bearing in each of the correct sizes and brought back the book to look up their speed rating.
He came back with NTN branded bearings and in the book it listed 6203 having a 19,000 rpm limit and the 6303 size having a 16,000 rpm limit. Finally! A sealed bearing from a name brand that has the right speed limit.
So, since then I've been working on getting the bearings rebuilt. I had to pause for a bit while I looked for a way to get the large bearing pressed out of the front face. Once removed, I was able to cut both bearings off (which was a p.i.t.a.). I couldn't get a puller in behind the bearings since the clearances are too tight, unfortunately.
So right now I'm ready to start reassembling when I got to thinking about replacing the slip rings while I'm at it. Mine look like they're pretty worn down so since I don't want to have to take the alternator back apart again and replace them in the future, I went ahead and ordered some from the links Digital Corpus gave. I ended up going the eBay route since it's a couple bucks cheaper and the shipping is better. Just so other people know, how long did it take to ship through Amazon?
Once I'm sure it's staying alive, I was planning on making a tutorial when I replaced them on the other alternator.
So now I'm at this point. Were you still planning on making that tutorial? The way I'm thinking it goes (just from looking at it):
1) melt the solder joints off the slip rings
2) remove slip rings straight up
3) insert new slip rings
4) re-solder the wires on
Any tips you want to add to this, DC?
A couple final thoughts:
I figured out why the "rebuilt" alternator that came in my passat failed so soon. They used a shielded bearing. Shielded bearings have a metal seal instead of a rubber seal that does not completely seal off the bearing. They can spin faster due to less friction, but they leave the necessity for cleaning and re-greasing. Grease can get out and dust can get in and that's a recipe for a failed bearing.
The bearings in the used, not rebuilt, alternator I purchased from one of the classifieds (either here or vwv) were sealed. The large one was a Koyo, and the small one was an NTN. I don't know for sure that those are the factory bearings, but they're both a name brand sealed bearing and the alternator did not say "remanufactured" anywhere. Just thought you all might like to know that information.
