Good morning all,
Having a bit of an electrical issue and hope someone has had something similar and knows of a fix.
For months my battery would drain overnight. As a temp fix I've been disconnecting the negative terminal cable, but have grown tired of this so today is diagnosis day.
I've followed the technical bulletin VW put out on battery drain issues, and believe I've narrowed it down to the anti-theft fuse located in the interior relay panel. In sleep mode, the measure voltage in this fuse is 1.4-1.8 mV and based on the current consumption matrix, it seems like a 317-407 milliamp draw.
To clarify, this is the 15A rated fuse located right above (and centered) between position 5 & 6 on the relay panel. (there is another fuse identical to this one, located to the left of it which has 0 milliamp draw while in sleep)
I'm assuming this is abnormal milliamp draw for this fuse when in sleep mode but could be mistaken?
Has anyone come across this before or has an idea on a potential fix?
Any help would be much appreciated. Thanks everyone!
