Reesetricted
Back story, the car started running rough as I was driving down a street. I got to the light and confirmed my diagnosis, and pulled into a parking lot. It died. I tested compression and it came back good and even across all cylinders. I dropped the pan and check the rods bearing to make sure it wasn't rod knock, they looked outstanding for a 265k engine. It would start sometimes, and it would stay running, mostly, if you kept giving it throttle. However, it was making loads of smoke and running like crap. Seemed like it was off a tooth or so. I tried to start it 1 last time to get it into the garage... It started, then died in the street as I was turning around. No hints of starting since then.(It now occurs to me that I might want to do another compression test.) So, I tore I the timing belt replacement procedure. The PO told me the timing belt\water pump was replaced at 225k, I bought it after he rear ended someone at 235k(I had a Jetta front end waiting to go on this golf). Serpentine belt tension was totally useless and the tensioners slack bolt was rounded... Belt cut. As soon as I got the timing belt exposed enough to see it's tensioner, I knew I found the problem. So much slack. Belt is\was just floppy. It surely skipped teeth.
So, here I am... A guy with a bunch of tools and no VCDS. How do I go about timing everything up? I can't see any timing marks on the cam gear. Crank pulley has a mark, injection pump has a hole to lock it, flywheel has a mark.... But, without the cam shaft, the others don't do much good. Would one of you kind humans direct me to the instructions for re-timing this thing?
