Geky
- Joined
- Oct 1, 2020
- Location
- Lithuania
- TDI
- 1.9tdi ALH tuned to 175hp/ VNT17, PP502's, PD150 intake, 3bar map
Hey guys, so i was searching for info regarding upgrading the ALH non pd version. I found out that i could use the pd130/150 intake manifold, vnt17 or gt2052v (found a thread where a member used one), injectors from AEL 150hp variant (the T4 or 2.5tdi audi). Now, ive read through so many threads and each n every one of em says different things, therefore i created this thread to get the required clarification. Will i need a bigger IC? Whats the difference between smic/fmic? Do i need to weld to fir the turbo? Will the injectors work or shall i just swap the nozzles instead? Do these nozzles require calibration or is it just for PDs? How about transmission? Brakes? Are there any other suggestions? Id gladly appreciate if you'd suggest different nozzles/injectors/turbo anything tbf. Im running a tdi90 alh with gt1749va and a tune at my local tuner.
Thank you in advance,
Geky.
Geky.
