got a recently purchased alh 2001. replaced the battery ( hard starts with not enough amps to turn it over fast enough), fuel cut off solenoid, thermo tee, fuel lines that leaked, fixed a clogged check valve in sending unit. also replaced the two common seals in the IP. after doing all this the car started and ran well enough to climb hills in 3rd or 4th at 45mph not not well enough to really go or drive highway speeds but it would idle really well. during this time the glow plug lights were flashing, so we checked using vcds but did not have any codes. then yesterday while driving back from store it died, so i stopped, reprimed the injectors and it managed to drive a block before i had to prime them again. this got worse for the next two blocks, after the second reprime the engine seemed like it could barely idle and it kept dying faster and faster. managed to get it close enough to push it the rest of the way home. i dont have any obvious fuel leaks on the IP from the top side. i had a perfect connection to the ecu after replacing the battery but after the car started to die over and over yesterday i could no longer talk to the ECU.
