rustybolts
Installed an IV line above the injection pump and return line below the pump! After vacuum return line and bleeding injectors, it started right away and ran for 1 or 2 minutes, then died ! Right after it died, i saw lots of air bubbles coming from the supply line and up to the IV container. Check and double-check both lines and clamps for leaks, including return line from injectors, couldn't find any! Outside of injection pump not leaking at all, not from the top gasket or the QA gasket , and the head seal is not leaking either , Just wondering if the Diesel Geek pump seal will solve this inside leak or there is other trouble in the injection pump? Already change filter and o'rings, but bypassed it to eliminate them. Original IP and never open. Is it time for a rebuilt pump?
