s3_luke
hi chaps, right got a problem with my mk2 caddy van, it started life as a 1.9 sdi code AEY, and has recently had a conversion to a TDI AHU.
So the engine went in fine and ran spot on, untill we discovered that the H/G had blown, not a problem untill it was replaced. The guy that done it for me was dropping it back to me untill it rattled itself to pieces, while waiting for recovery he whipped the head off ( roadside) and discovered that the cap on top of the lifter had been smashed to pieced, but no valve or piston damage. It was replaced and ran at his house for a good 20 mins untill things got loud (like hammers banging together) so he whipped the head back off and found nothing wrong, the bottom end turns over sweet, as does the head (while off), but while the engine was bolted up you couldnt turn it as it was jammed :/, like the valve was bouncing the piston but all the timing was literally perfect, could it be lifters failing and valves just and just tapping the pistons? any info would be amazing as its my work van and its causing major issues, cheers lads, luke
