My car has edc15 ecu, just dont know on top of my head which one is it.. Would also love to tune the car via obd, but I know that my ecu hasnt got that feature. Is it hard to retrofit another ecu? That I can write on it?You better get an vacuum actuator fitted on it although the electronic actuator has been done on the Edc 15...I think that MSA15 will strugle controlling the vnt actuator on the gtb2260vk turbo...
With all the canbus stuff in these cars. I think it would be hard. And get one with a vac actuator. Mtb2260 is what's in my mk6My car has edc15 ecu, just dont know on top of my head which one is it.. Would also love to tune the car via obd, but I know that my ecu hasnt got that feature. Is it hard to retrofit another ecu? That I can write on it?
If your car is A4 B5, then there is a version with EDC15V (flashable over obd) AVG (AFN) engine from 1999-2000 B5 facelift. You can transplant that to your car. Maybe there is one for Passat if it's the case, We have to check.My car has edc15 ecu, just dont know on top of my head which one is it.. Would also love to tune the car via obd, but I know that my ecu hasnt got that feature. Is it hard to retrofit another ecu? That I can write on it?
A friend of mine is looking at an A4 B5 project after he sold his Wrangler. The suspension and toyo tires will be installed next week before being delivered to the new owner. We'll consider your tips here if take her in.If your car is A4 B5, then there is a version with EDC15V (flashable over obd) AVG (AFN) engine from 1999-2000 B5 facelift. You can transplant that to your car. Maybe there is one for Passat if it's the case, We have to check.
You need electronic actuator that can be controlled on PWM, not CAN. One is on GTB2056VL, I don't have the part number.
