rotarykid
- Joined
- Apr 27, 2003
- TDI
- 1997 Passat TDI White,99.5 Blue Jetta TDI
I accidentally poured some B100 5.6 gals into my 07 Corolla which had maybe 6 gals in to begin with a couple of weeks ago . Drove the car for about two miles then drained the tank completely or as much as I could get out . It threw a code for running too lean , has thrown it couple of times since . I filled to brim with premium from the fill amount I'm sure maybe 3/4 to a gal of the BD100 mix ( B50/E10 85 oct ) was still in the tank . So in the end I had a 5 % BD mix in with E10 91 oct in the tank .
I ran the tank almost dry then refilled to check fuel economy . To my surprise I achieved ~34.5 on the city only loop with a lot of "N" use at a stop and when coasting with no power required . Normally my wife would achieve 30-31.7 max on similar loops at similar speeds with my wife behind the wheel , I have over 10k miles of identical data to back those numbers up . I've pushed the thing to just short of 37 mpgs a couple of times when I was the only driver on lower speed city only loops . I always fill to the top until it stays there and all the gas in the Denver area is at least E10 so that is what I filled with . After the missfuel I filled with E10 91 octane which is the highest octane available to get up here .
My question is why did I see such a jump in mpgs with the introduction of the B100 to tank ?????????
And what is that running too lean code about ???
Is running a low % of BD a good idea to improve mpgs in a gasser????
What harm could a low % of BD being added to E10 RUG 85 octane up here cause to the engine or emissions ????? What about adding some BD to a E85 / E10 RUG mix , note I never exceed E30-E35 in anything ?????
A note , I've been splash blending E85 & E10 85 oct for a maximum of E30-35 gasoline for about two years now in all the gasoline vehicles I have to drive .
