perrya
If your engine code indicates the ABS pump is bad, can I just replace the pump or do I need to replace both the pump and controller of a replacement? I ask because if just the pump is bad, I can detach the pump from the controller and use the non-defective original one. This way I can avoid reprogramming it correct?
Can I do this? or, if the pump is bad, you have to replace both the pump and controller and therefore need to reprogram the controller to you car?
