Tdihelpneeded
Hey all I have a 2008 A4 2.0l TDI Cabriolet 7 speed cvt, I have a few problems
The car starts fine I can't see any Smoke at any time, the car takes 2 seconds to move from stand still, it just boosts to 3k rpm and then starts moving its 0-62 time is way below spec, it also struggles after 80mph (takes a long time to reach 100mph) seems I do not have much top end power, it struggles to go past 100mph and if going up gradient it struggles from 60mph, its starts fine, no leaks BUT ITS ABUSING FUEL I'm seeing sometimes 18MPG, I have so far done the following
Cleaned egr (was terrible)
Air filter wasn't bad
Changed thermostat
Changed map sensor
Replaced oil
Oil filter
Fuel filter
Tandem pump
Crank sensor
It has not solved my problem the following readouts are from idle in neutral and 2800rpm in neutral, I am fairly new to diagnostics but it seems that perhaps I have a clogged DPF and a problem with Injector 4, or possibly cam/lobe problem can anyone confirm my thinking (I haven't done a compression test yet) THANKS ALOT
IDLE 2800RPM
ASR Limitation 1270Nm 1270Nm
Camshaft speed 420 /min 1386 /min
DPF coefficient 6%
DPF carbon mass 71
DPF learned value 0%
EGR pos ctrl deviation 323 323
EGR neg ctrl deviation -326 -326
EGR ctrl deviation 0.00 275
EGR duty cycle 82% 100%
EGR duty cycle (alt sensor?) 12% 0%
Egr pos intake flap (specify) 95% 100%
Egr pos actuator (actual) 15% 0%
Egr pos actuator (specify) 15% 0%
Egr actuator learned -8.2% -8.2%
Engine speed 840 /min 2793 /min
Exhaust gas recirc(specify) 280mg/H 635mg/H
Exhaust gas recirc(actual) 275mg/H 540mg/H
Fuel consumption 4.00/lh
Generator load 40% 22%
Injection duration(post inject) 0.00KW 0.00KW
Injection start(specify) 0.0n.OT 8.7v.OT
Injection start quantity 18.12mg/H 18.12mg/H
Injection start(post injection)30.4n.OT 30.4n.OT
Injection quantity 8.78mg/H 10.16mg/H
Injection quantity(post inject) 0.00mg/H0.00mg/H
Injection duration (specify) 8.76KW 2.55KW
Injection quantity (error) 1.93mg/H 0.00mg/H
Injection quantity (offset) 0.00mg/H 0.00mg/H
Injection quantity deviation
Cyl 1 -0.28 -0.61
Cyl 2 -0.68 -0.82
Cyl 3 0.07 0.35
Cyl 4 0.92 1.04
Injector switch time deviation
Cyl 1 -11 2
Cyl 2 -1 8
Cyl 3 -5 1
Cyl 4 19 6
Lambda sensor actual 3.60 5.0
Maf(actual) 285mg/H 530mg/H
Maf average 49.8g/s
Maf(calculated) 51.2g/s
MSR Limitation -1280Nm -1280Nm
Oil level 23.0 mm 24.0 mm
Oil wear index 20 72
Oil soot index 218 126
Pressure boost(actual) 1010mbar 1244mbar
Pressure boost(specify) 1071mbar 1244mbar
Pressure chrg ctrl duty cycle 95% 49%
Pressure difference DPF 10.20 76
Pressure difference offset 0.00 0.00
Pressure atmosphere 1010mbar 1010mbar
PTN ratio 1.89 1.04
Start synchronisation 48 48
Smoke limitation 139Nm 181Nm
Temp before DPF 222.0 C
Temp before turbo 186.0 C 276.0 C
Temp After DPF 180.0 C 243.0 C
Temp in DPF 174.0 C 228.0 C
Temp fuel 98.1 C
Torque engine 59Nm 71Nm
Torque request (driver) 0Nm 72Nm
Torque restriction 139Nm 181Nm
Torque limitation 198Nm 339Nm
Torsion value 0.49Kw 0.0Kw
Changed thermostat
Changed map sensor
Replaced oil
Oil filter
Fuel filter
Tandem pump
Crank sensor
IDLE 2800RPM
DPF coefficient 6%
DPF carbon mass 71
Cyl 1 -0.28 -0.61
Cyl 2 -0.68 -0.82
Cyl 3 0.07 0.35
Cyl 4 0.92 1.04
Cyl 1 -11 2
Cyl 2 -1 8
Cyl 3 -5 1
Cyl 4 19 6
Maf average 49.8g/s
PTN ratio 1.89 1.04
Temp fuel 98.1 C
