Mikkijayne
Hi all,
Background: I have two A4s and an A6 all with AFN engines. The two A4s are identical - same year, same spec, same ecu, standard 110hp engine. The A6 is tuned to >200hp with bigger everything. EGR is disconnected on all of them. They are all timed in-spec with VCDS.
The A6 and one of the A4s are blowing hot air within 2 miles of my house, and up to temperature a few miles after that. The problem A4 doesn't blow hot air until 10-12 miles, and needs properly thrashing to get up to temperature.
The only difference between the three is that the problem car still has its viscous fan whereas the good ones have electric instead, but I don't see how that should affect the warm-up when its driving so have mostly ruled it out.
The problem car has a good water pump, new thermostat, new rad, new sensors, good flow through the heater core, fresh coolant. VCDS and a hand on the hoses match what the gauge shows. The coolant glow plugs are working fine, although with air temp at 14C none of the three cars are using them.
I'm stumped now. Anyone got any ideas please?
