EmeraldTDI
Hey folks,
My 97 Jetta TDI is having problems starting. I'll put the key in, the battery seems fine (gauges, lights, radio, fan all working fine), but I turn the key and absolutely nothing happens (no crank at all, so I conclude glow plugs are NOT the problem), just silence from the engine.
So, I pushed it, popped the clutch, it starts fine. I've had to do that twice since yesterday.
I took it to a trusted mechanic who tells me he can't see anything wrong with the car, he says the battery is fine, the starter is fine...that bothers me, because the car was having difficulties, SOMETHING must be causing the problem...
Anyone have any experience with these curious symptoms?
I have already replaced the ignition switch under recall warranty (plenty of info in other posts on this), so I don't THINK it's an ignition switch problem (especially since, as already mentioned, everything else works when the ignition is turned except the car won't start).
