bhodgkiss
As I understand it, the stop screw sets the starting position of the vanes, so when the engine is switched off, the actuator moves back (no vacuum) and hits the stop screw. So thats the starting point of the vane position at low rpm.
Is that correct? So if I want to improve low end boost as the boost is lagging the request, I adjust the stop screw slightly?
The rod length affects the rate at which the vanes move? is that correct?
And then on top of this there's the N75 solenoid duty cycle map on the ECU which can also be changed......
So what do I need to do if my low end boost is lagging the requested boost please?
Thanks!
Thanks!
