Rcbamm
- Joined
- Dec 29, 2012
- Location
- South FL
- TDI
- 05 Golf TDI BEW SOLD. 2015 Golf TDI VW boughtback. Own: 15 GSW TDI. 99.5 Jetta TDI
Hi all,
I'm new to this forum, I currently own a 05 Golf TDI and my 99.5 Jetta TDI that recently broke down..
I'm trying to get the Jetta to be my daily airport car, and keep my Golf for a weekend driver. I stopped driving the Golf because the PD cam is wearing and I therefore started driving the Jetta until I replaced the cam on the Golf. Never was I expecting the Jetta cam to fail the same as how I was afraid of the Golf cam failing!
I pretty much got the Jetta from the original owner with all maintenance receipts since new, I had great confidence in the car because it ran great and I could get 800+ miles to a tank. I always shifted at 1800-2500rpm and I always ran Lubro Moly 505.1 spec oil.
A couple weeks ago, cruising the back roads at 60mph, the engine lost loads of power and the car started shuddering, what the... I got the car to my work and pulled the valve cover and found broken metal pieces from one of the cam followers.
My questions are, what caused this to happen? Did the valve hit the piston causing the cam follower to break into pieces? Or did the follower structurally fail?
I talked to an auto mechanic and he said to just pull the cam and pull the rest of the follower out, smooth out the gouged edges and throw a new set of cam followers in the head and see if it runs before I invest in a new head to save money, but I do not want to risk ruining the engine nor do I really want the head to fail in any other way when driving it. But then again I'm curious to see if this quick fix will be good to commute to and from work which is 50 miles a day to save the $1100+ on a new OEM head
