dieseljunkie
Bought Sept 09 from a couple in MA. It was my first TDI. My intent was to fix it up with the help of TDI club and convert it to run on WVO. I have been running WVO successfully since 2005 with over 250k miles total on 3 different IDI diesels (Peugeot, Mercedes and a VW Jetta IDI) with no engine related WVO problems, pretty good track record? I've been working on the 96 Passat over the last 3 years but have finally decided against converting it to WVO because of the more complex TDI engine that may not be as suitable for WVO as the IDI's and thus the reason I am selling it. I think many here will agree that is a good decision.
Since owning the Passat, I have driven a total of about 5k miles. Why so little? I have 3 other cars registered, 2 of them run on WVO and I drive them because the fuel is almost free! So the Passat got driven very little, and never on WVO. It currently has under 160K on the ODO.
My plan was to get it into good shape mechanically and cosmetically. Most of the work done has been just about all mechanical.
The good:
-Working AC- blows cold, I replaced the leaky condenser with a new one and evacuated and recharged with 134A.
-Engine starts easily and runs with lot's of pep
-new Bosch injector nozzles (from idparts) 3k miles ago
-There are no leaks of any kind
-New Continental timing belt and tensioner 5k miles ago. Timing set exactly in the middle of the graph with VCDS ,per spec.
-New Bilstein TC rear shocks 5k miles ago
-New serpentine belt 5K miles ago
-New group 49 battery one year ago
-New N75 5k miles ago
-New glow plugs 5k miles ago
-New G12 pink coolant 5k miles ago
-New power steering fluid 5k miles ago (comes in a green can) CH11?
-New Redline MTL fluid in tranny 5k miles ago
-Wireless remote door lock system added (banjo FOB). All door locks work.
-All power windows go up and down
-4 new Michelin 19570R14 X-radials 5k miles ago
-BK ECU -no fault codes
-cluster from a gasser B4 GLX converted to diesel by Derek White- Odometer set to reflect true mileage
-EGR delete- added resistor no fault code
-5th injector delete- added resistors- no fault code
-Baldwin fuel filter, relocated for easy access with clear nylon supply and -return lines for instant check for bubbles in fuel.
-Clear injector return lines.
-Boost gauge
- R&R 2 brake lines at right rear caliper with Cunifer alloy lines (won't rust). Brakes all work and stop well.
-Charging and cooling system works fine
-Has a great sounding Alpine audio system from PO. I think the bill was like $1500.
Did I forget anything? If so I will update.
The bad:
Some minor rust spots on door corners and small dings here and there.
I did replace the R rear door, which is a different shade of black but you can't tell unless you look closely.
Suitcase muffler fell off so would need some exhaust work.
At cold start, when the ambient temp is below30 to 40F, it's smokes for a minute before clearing up. I've done a lot of work to solve it but have been unsuccessful- which includes new glow plugs, new nozzles, timing adjustment. I think it is the valve stem seals. I bought a set of valve stem seals from idparts but have not installed them. They will be included. It does not smoke now in the summer (from a cold start).
I have tried to describe the vehicle as best I can. If you have any questions, please ask. Serious inquiry only.
The good:
-Boost gauge
The bad:
