Not only valves and flame front affect max revs. The actual speed of the piston should be below 4000 ft/min, otherwise the rings don't hold and the hot gasses blowby into the crankcase!
The TDI with 95.5 mm stroke does about 6400 rpm at 4000 ft/min. A cummins with 120mm stroke does 5069!
> I copied this from a post on the BMW list. I don't know who did
> itSorry
> if you know who you are:
> <quote on>
> 1. Normal Condition
> Gas pressure in the upper cylinder holds the ring down
> against the bottom of its groove and out against the
> cylinder wall, forming a seal.
> Gas Pressure
> \| v
> \| v| .
> \| :| Left . Right
> \| v|------- Cross-section . Side of
> \| :.v.... | of Piston . Piston
> \|[[[]] <: |\ . (not shown)
> \| | \ Ring Groove .
> Cylinder \| | \ .
> Wall \| | Piston Ring .
> 2. Too Much Piston Acceleration
> Piston acceleration lifts the ring, shutting off pressure
> behind the ring and breaking the seal. The ring groove
> is damaged by constant mechanical pounding. Hot
> combustion gases get past the ring, overheating it and
> the piston.
> Gas Pressure
> \|v | .
> \|: | Left . Right
> \|v |------- Cross-section . Side of
> \|:[[[]] | of Piston . Piston
> \|v \ |\ . (not shown)
> \|v | \ Ring Groove .
> Cylinder \| | \ .
> <quote off>
> The result? Increase wear on the piston, piston ring, rods, crank,
> etc.
> etc. etc.
> Thanks whoever made the great diagrams!
> Okay simple enough. Now comes the question of determining at what RPM
> this occurs. I turn to an article out of Gordon Jenning's "Two Stroke
> Tuner's Handbook". True we have a four stroke, but the principle
> should
> remain the same. Anyway, the formula is as follows to determine the
> maximum speed allowable before things turn bad:
> Cm = 0.167 x L x N
> Cm = mean piston speed in feet per min
> L = stroke in inches
> N = crankshaft speed in rpm
or cm= 0.00657479 x L (in mm) x N
> This gives you the actual piston speed in feet per minute. Then you
> go to
> this handy little table (I don't know how the determined it, but they
> did)
> to figure out where your engine stands.
> Mean Piston Speed Result
> Under 3,500 ft/min Good reliability
> 3,500-4,000 ft/min Stressful, needs good design
> Over 4,000 ft/min Very short life
> Okay, this is all good and well, but how does it apply to our car
> Well
> let us see:
> VR6 Engine
> Stroke = 90MM (out of technical manual)
> 90MM = 3.54 inches (courtesy of handy HP 19BII
> Calculator)
> Okay so plug this stuff into the formula:
> First with stock rpm
> CM = 0.167 x 3.54 x 6500 (I think this is stock redline)
> CM = 3,842.67 ft./min
> Okay that isn't SO bad. We have already determined the VR6 is a
> fairly
> robust motor and is quite well built. Now let's figure it out for two
> tuner chip rpms (6900 my P-Chip, 7300 Garrett's)
> P-Chip
> CM = 0.167 x 3.54 x 6900
> CM = 4,079.14 ft./min
> Garrett
> CM = 0.167 x 3.54 x 7300
> CM = 4,315.61 ft./min
> Okay now it is true these speeds are reach for only a few seconds
> (providing you don't hang at the rpm) but there can be no doubt that
> revving above the stock redline can, and will, be harmful to the life
> or
> your engine. Even if the rings float just once, hot gases would
> escape to
> the bottom end. Figure this, let's say you hold the engine at 7,300
> rpm
> for 2 seconds.
> 7,300RPM = 121.67RPS (Revs per second, 7,300/60)
> Divide by six to figure out the revs for each cylinder
> 121.67/6 = 20.28.
> That means that each cylinder has its rings float and gases escape to
> the
> bottom end 20 times (providing the rings are indeed floating). Or a
> total of 121 times for the whole engine! All in the space of 2
> seconds!!!
> I don't care what anyone says, if the rings are floating damage and/or
> increased wear is happening.
> Now these formulas are just the opinion of people, but I think that
> even
> if you add a bit of safety into the formula even then 7,300 rpm would
> seem
> to cause extreme wear on your car. Here are some examples of other
> cars
> with what would be considered OVER BUILT engines.
> Redline Stroke Piston Speed
> Engine (rpm) in, mm (ft/min)
> BMW E36 M3 6,800 3.38, 85.8 3,838
> BMW E28 M5 6,900 3.31, 84 3,814
> BMW E34 M5 7,200 3.39, 86 4,076
> Just for comparison
> CBR600 (bike) 13,250 1.78, 45.2 3,939
> Okay, I know they are all BMW engines, but they are ALL M engines.
> And
> not one of you, even Wally
, can argue these are not well built
> engines
> built to take a load of stress. Hell the rumor is that BMW picked
> old M3
> four cylinder engine blocks right off the factory line to make F1
> engines
> out of them. I find it funny that only one of them goes over the
> danger
> zone (barely), but even then it's at ridiculous RPM and not even
> close to
> what the VR6 pistons are doing at that speed. Plus this is with a
> Dinan
> Chip that STILL recommends maximum constant engine speed be limited to
> 6500 RPM ">
> What's the point of all this?
> Now will this reduce the life of your engine noticeably? Maybe yes
> Maybe no.
> One thing, I am not an expert so I would like some responses from the
> group.
> Thanks,
> Kris,
> '93M5
