wakdady
I'm finally wanting to do the 5th gear swap and now that I'm looking, I can't seem to find one.
Anyone know where I can obtain one?
Actually to have the equivalent fifth gear in an 02J as compared to the 6th gear in an 02M diesel geared six speed, you would need a 0.626 to be the same which gives you a final ratio of 2.129. A 0.681 gives you a final ratio of 2.308. A 0.658 give the ratio of 2.23. A 0.622 gives the final ratio of 2.108. They did make a 0.622 but not sure it is still available. The fifth gear in the 02m has a final ratio of 2.55 and in the 02j it is 2.56 or virtually identical..681 keeps rpm about the same as being in 6th gear in the 6 speed transmission swap, and the rpm drop from 4th to 5th isn't bad or exaggerated..
I'm going to trust you on this one. I had calculated the speeds in highest gear for my car using each transmission's ratios a while back and came to that conclusion (although seemingly wrong). Maybe I had calculated with Ring and Pinion gear 1; thank you for the correction, very useful info.Actually to have the equivalent fifth gear in an 02J as compared to the 6th gear in an 02M diesel geared six speed, you would need a 0.626 to be the same which gives you a final ratio of 2.129. A 0.681 gives you a final ratio of 2.308. A 0.658 give the ratio of 2.23. A 0.622 gives the final ratio of 2.108. They did make a 0.622 but not sure it is still available. The fifth gear in the 02m has a final ratio of 2.55 and in the 02j it is 2.56 or virtually identical.
You still have it? Message me on Instagram, and name hereIf anyone interested I have .681 for sale :
FS: VW 5th gear .681
I Have 5th gear .681 for sale . This gear is no longer available and this was most popular gear for upgrade. The .681 will drop RPMs by approximately 300-400 rpm, depending on wheel and tire sizes. This is original VW gears and you can conform here that is .681 Gear set here at Kerma by part...forums.tdiclub.com
