hello everyone. Today i scanned my car for the first time. here are the results:
6 Faults Found
4698 - Function Restriction due to Received Malfunction Value
U1113 00 [032] - Open or Short to Plus
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 18
Reset counter: 32
Mileage: 5608 km
Date: 2009.09.06
Time: 18:00:00
4699 - Function Restriction due to Received Malfunction Value
U1113 00 [032] - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 18
Reset counter: 32
Mileage: 5608 km
Date: 2009.09.06
Time: 18:00:00
5608 - No Communications with Steering Angle Sender (G85)
U0126 00 [032] - Implausible Signal
Freeze Frame:
Fault Priority: 0
Fault Frequency: 18
Reset counter: 32
Mileage: 5608 km
Date: 2009.09.06
Time: 18:00:00
9805 - Steering Column Control Module: No Communications
U0212 00 [032] - Check DTC Memory
Freeze Frame:
Fault Priority: 0
Fault Frequency: 18
Reset counter: 32
Mileage: 5608 km
Date: 2009.09.06
Time: 18:00:00
4714 - Steering Column Control Module: No Communications
U0212 00 [032] - Open or Short to Plus
Freeze Frame:
Fault Priority: 0
Fault Frequency: 18
Reset counter: 32
Mileage: 5608 km
Date: 2009.09.06
Time: 18:00:00
4891 - EGR Valve (N1
: Malfunction
P0403 00 [096] - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 18
Reset counter: 32
Mileage: 5608 km
Date: 2009.09.06
Time: 18:00:00
My car was made on august 2010, i cant understand that 2009 date. I visited the dealer because my steering was pulling dramatically to the right. on irregular roads it actually felt freaky, it was actually hard to counter it. They said they didnt find anything and corrected tire pressures and lined the steering. it feels better now, dont know if its solved, cause i dont have any servotronic four wheel drive car to compare with. any observations? Should i dig deeper or should i erase all faults and move on?
What do you think its up with the EGR? Car has 11500km, and i use premium diesel. wierd the error at exactly the same time as all the others. (on dealer?)
im quite confused, its a quite new car...
thanks
6 Faults Found
Freeze Frame:
Fault Priority: 0
Fault Frequency: 18
Reset counter: 32
Mileage: 5608 km
Date: 2009.09.06
Time: 18:00:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 18
Reset counter: 32
Mileage: 5608 km
Date: 2009.09.06
Time: 18:00:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 18
Reset counter: 32
Mileage: 5608 km
Date: 2009.09.06
Time: 18:00:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 18
Reset counter: 32
Mileage: 5608 km
Date: 2009.09.06
Time: 18:00:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 18
Reset counter: 32
Mileage: 5608 km
Date: 2009.09.06
Time: 18:00:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 18
Reset counter: 32
Mileage: 5608 km
Date: 2009.09.06
Time: 18:00:00
thanks
