chillman1971
Has anyone tried running a 225/50/17 on a mkvi tdi Golf? If so did you have any clearance issues?
I went up to 235/45/17 and I'm very happy with the change. I have wheels from a B6 Passat, 17" x 7.5" ET47. The tires are "Grand Touring" all season Michelin Primacy MXM4 235/45/17 94H. I also run the tires at 32 psi. It is quite comfortable, but still feels very sporty too. The fatter taller tires also fill the fenders a bit more, which I like, and there is no poke or any rubbing at all....your better bet would probably be a 235/45/17 as it adds some sidewall while maintaining almost the same overall diameter...
"Ve are ze German engineers, und ve have calculated ze correct sizes for your car! YOU MUST NOT WAVER FROM OUR CHOICES!!! Failure to follow ze correct sizes will result in a visit from the OEM polizie! VE KNOW VERE YOU LIVE, UND VE HAVE VAYS OF MAKING YOU COMPLY!!!"PLEASE DON'T. Stick with the standard 205/55-16 or optional 255/45-17.
There is no reason on God's green earth to go crazy on odd tire sizes,
unless it is a fashion statement, which in my opinion is the wrong reason
to pick tires. The German engineers have calculated all parameters, and
the car is made for the above two sizes.
My wheels are a little different than the stock wheels. My stock Porto wheels were 17" x 7" ET54. My current wheels are 17" x 7.5 ET47. The wider wheel with lower offset, is essentially the same on the inboard side, but it moved out about a half inch on the outboard side. My front wheel/tire is almost flush with the lip of the fender and the rear is still tucked. I like how it gave me a wider wheelbase with a stockier look and the wider wheel is better suited for the 235 width tire....ksing44 your tire selection looks good. Do the rims you selected have the same back spacing as the stock tdi rims?Thanks for the pics.
I know what you mean about searching for a car. I finally found mine on a ship headed to a dealer in Atlanta Georgia, then paid to have the car shipped to me at my home in Pennsylvania....You have the exact car my wife was looking for when we were called by the dealer for the one we have now. 4 month of searching
215-50-17 Continental Extreme Contact DWS. No clearance issues. Love them.Has anyone tried running a 50 series tire? If so did you have any clearance issues?
