alhbeliever
Hi guys,
I am currently building a 300 hp alh. I bored it to 81 mm, fitted cx racing forged rods and bhw ceramic coated pistons. I also installed a 3 hole head gasket to reduce compression. As for the head, i ordered a 272 degree/10.4 mm lift dbilas cam along with stiffer valve springs. For the fuel, i have an in tank pump paired with an 11 mm pump and .360 gibonata race nozzles. I ported the head and installed a brm intake manifold (allegedly the best flowing tdi manifold sold in America). For reliability purposes, i would like to limit the torque to 270 wlbsft to the wheel. That way i can hit that magical 300 whp number (@6k) and keep my 02j transmission safe. The only mods done to the trans are a second hand lsd from ebay and a .592 5th gear. As for the turbo, i was thinking hx30 because its the smallest turbo that can flow how much i would need and can be found at around 500$ shipped, but i haven't bought one yet. Suggestions would be great. My turbo manifold is equal length 4-2-1 style t3 made by myself. The torque curve that i would like would put me in vacuum from idle to around 3k for economy (this is still my daily driver) and 270 wlbsft of torque from 3k to 6k. I planned to put a low boost spring in the wastegate and control the boost with a solenoid. For example, I could put a 10 psi spring in the wastegate and letting it open until 3k. After 3k, the boost controller would module the boost all the way up to 6k rpm (boost increasing with rpm while staying at around 270 wlbsft until redline). The max boost i plan running is around 40 to 45 psi. The problem is, a friend of mine told me that boost wont be able to reach 40 psi with a low boost spring in the wastegate since exhaust gasses would open the 10 psi spring from the inside while trying to increase boost regardless of what the boost solenoid is signaling. Is that possible? If it is what would you guys suggest as a solution? What does my set up lack? Any input is greatly appreciated.
