cortsener
Hi all, my wife has a 2015 VW Jetta TDI CVCA and it has been sitting since March (she works from home now since the pandemic started). I know cars don't like to sit. First, she called me one day and said the car wouldn't start, the battery was shot, so I replaced the battery. Then a few weeks later, I noticed that it was leaking coolant and after removing a couple covers, discovered that it was leaking a steady stream from the water pump. The car has 77k miles, so I figured it might just be due. I ordered a timing belt kit with water pump and the timing belt tool kit from Kerma TDI. I replaced all the idlers, tensioner, serpentine belt, etc. and it all went very well. We decided to take the car for a ride on Sunday and it drove fine for about 100 miles. As we started up a gradual hill, I noticed a distinct skipping feeling and the glow plug light started flashing. We pulled over, took a peek under the hood and all looked normal. Restarted the car and drove it home. On the way home, the check engine light also came on and the car felt like it was now normally aspirated - no boost. I assume it's in some sort of limp mode. I ordered a VCDS that day and pulled the codes today. I'm wondering if maybe I disturbed something or forgot something while changing the timing belt or maybe it's just another symptom of sitting all year. It's right around freezing outside now and the car won't start.
Side note, the car got all the emissions "fixes" at the dealer.
Any input would be much appreciated!
Thanks, Cortlandt
Here's the data:
Tuesday,05,January,2021,18:24:06:04048
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
Data version: 20201125 DS322.1
www.Ross-Tech.com
VIN: 3VWLA7AJ5FM229108 License Plate: NICOLE
Mileage: 124150km-77143mi Repair Order:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 04 08 09 15 17 19 25 2E 44 56 77
VIN: 3VWLA7AJ5FM229108 Mileage: 124150km-77143miles
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
Address 01: Engine (J623-CVCA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 997 016 E HW: 04L 907 309 K
Component: R4 2.0l TDI H20 9465
Revision: 8AH20---
Coding: 011D0012042410084000
Shop #: WSC 09113 444 00000
ASAM Dataset: EV_ECM20TDI01104L997016E 004002
ROD: EV_ECM20TDI01104L997016E.rod
VCID: 3537252D85C18BA3904-8060
19 Faults Found:
5231 - Fuel Rail/System Pressure
P0087 00 [096] - Too Low
Intermittent - Not Confirmed - Tested Since Memory Clear
4123 - Sensor Reference Voltage A
P0641 00 [175] - Open Circuit
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 124025 km
Date: 2021.01.03
Time: 14:31:29
Engine RPM: 2054.00 /min
Normed load value: 50.6 %
Vehicle speed: 101 km/h
Coolant temperature: 92 °C
Intake air temperature: 83 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 14.360 V
Unlearning counter according OBD: 40
Turbocharger 1 turbine input: temp. sensor 1: B1: raw value: 673.6 °C
Turbocharger 1 turbine output: temp. sensor 1: B1: raw value: 523.9 °C
Particulate filter input: temp. sensor 1: bank 1: raw value: 643.7 °C
Particulate filter output: temp. sensor 1: bank 1: raw value: 591.2 °C
EGR temp. sensor 2: B1: raw value: 53.0 °C
Shut-off timer: last engine shut-off time: 1103 s
25730 - Control Module for Reductant Quality
U02A2 00 [096] - No Communications
20173 - Charge Air Cooler
P026A 00 [096] - Efficiency Below Threshold
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 123933 km
Date: 2021.01.03
Time: 12:45:49
Engine RPM: 1731.00 /min
Normed load value: 34.9 %
Vehicle speed: 97 km/h
Coolant temperature: 91 °C
Intake air temperature: 58 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.140 V
Air mass at air mass meter 1: 80.5 kg/h
EGR temp. sensor 2: B1: raw value: 78.5 °C
Outside temperature sensor 1: B1: raw value: 6.0 °C
Intake air temperature before throttle valve: calculated: 0.0 K
Charge air cooler output: temp. sensor 1: B1: raw value: 68.3 °C
Heater supp.pump 1 bank 1 charg.air cool.circuit: activat.: 95.00 %
Turbocharger 1 charger output: temp. sensor 1: B1: raw value: 58.4 °C
5158 - Diesel Particulate Filter; Differential Pressure Sensor
P2456 00 [101] - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 124022 km
Date: 2021.01.03
Time: 14:29:06
Engine RPM: 1472.50 /min
Normed load value: 0.0 %
Vehicle speed: 83 km/h
Intake air temperature: 71 °C
Voltage terminal 30: 14.260 V
Particle filter: air pressure sensor 1 bank 1: raw value: 13 hPa
Particl.filt.: different.press.sensor 1 bank 1: adaptat. value: 13 hPa
Par.fil: diff.pr.sens.1 bank 1: offset: 1 hPa
Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: 0 hPa
Outside temperature sensor 1: B1: raw value: 2.0 °C
Particle filter: soot mass measured: -16.93 g
Particle filter: soot mass calculated: 21.13 g
9764 - Exhaust Pressure Sensor 1
P0470 00 [040] - Malfunction
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 123901 km
Date: 2020.12.20
Time: 15:22:59
Engine RPM: 0.00 /min
Vehicle speed: 0 km/h
Coolant temperature: 14 °C
Intake air temperature: 12 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 11.860 V
Unlearning counter according OBD: 39
Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
Exhaust recirc.valve 2 bank 1: posit.feedback - Specified value: 0.00 %
Exhaust recirc.valve 2 bank 1: posit.feedback - Actual value: 0.00 %
Exhaust recirc.valve 2 bank 1: posit.feedback - Offset closed: -0.17 %
Exhaust recirculation valve 2 bank 1: monitoring - status-Bits 0-7: 55
Exhaust recirculation valve 2 bank 1: monitoring - status-Bits 0-7: 0
Exhaust recirculation valve 2 bank 1: monitoring - status-Bits 0-7: 2
Exhaust recirc.valve 2 bank 1: posit.feedback - Raw voltage: 704.6 mV
5253 - Diesel Particle Filter; Differential Pressure Sensor
P2452 00 [032] - Elect. Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 124022 km
Date: 2021.01.03
Time: 14:29:29
Engine RPM: 1513.00 /min
Normed load value: 49.4 %
Vehicle speed: 85 km/h
Voltage terminal 30: 14.280 V
Particle filter: air pressure sensor 1 bank 1: raw value: 1042 hPa
Particl.filt.: different.press.sensor 1 bank 1: adaptat. value: 1042 hPa
Particle filter: soot mass calculated: 20.53 g
5262 - Diesel Particle Filter; Differential Pressure Sensor
P2454 00 [175] - Short to GND
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 124026 km
Date: 2021.01.03
Time: 14:31:30
Engine RPM: 1738.50 /min
Vehicle speed: 99 km/h
Intake air temperature: 82 °C
Voltage terminal 30: 14.320 V
Particle filter: air pressure sensor 1 bank 1: raw value: -249 hPa
Particl.filt.: different.press.sensor 1 bank 1: adaptat. value: -253 hPa
Particle filter: soot mass calculated: 16.23 g
5290 - Throttle Actuator Control Circuit
P2100 00 [096] - Open Circuit
9647 - Reductant Injector Valve (Bank 1)
P208E 00 [096] - Stuck Closed
18875 - Cruise Control Switch (E45)
P0568 00 [032] - Implausible Signal
8621 - Sensor 1 for Exhaust Temp Bank 1 (G235)
P0544 00 [044] - Circuit Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 123901 km
Date: 2020.12.20
Time: 15:22:58
Engine RPM: 925.50 /min
Normed load value: 20.4 %
Coolant temperature: 89 °C
Intake air temperature: 40 °C
Voltage terminal 30: 14.060 V
Turbocharger 1 turbine input: temp. sensor 1: B1: raw value: 1000.0 °C
Turbocharger 1 turbine output: temp. sensor 1: B1: raw value: 149.3 °C
Particulate filter input: temp. sensor 1: bank 1: raw value: 151.8 °C
Particulate filter output: temp. sensor 1: bank 1: raw value: 192.3 °C
EGR temp. sensor 2: B1: raw value: 53.6 °C
Shut-off timer: last engine shut-off time: 14 s
10203 - Random/Multiple Cylinder Misfire Detected
P0300 00 [237] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 124030 km
Date: 2021.01.03
Time: 14:35:50
Engine RPM: 2357.00 /min
Normed load value: 99.6 %
Vehicle speed: 56 km/h
Coolant temperature: 90 °C
Intake air temperature: 57 °C
Voltage terminal 30: 14.340 V
Mean injection quantity: 19.49 mg/stroke
Mass airflow sensor 1 bank 1 airflow: raw value: 709.5 mg/stroke
Fuel temperature sensor 1: B1: raw value: 35.7 °C
O2 sens. 1 bank 1 upstrm oxi cat: raw value: 2.5891
Pressure control valve adaptation factor: 1.0481
Injection release status-Bits 0-7: 28
27355 - Cylinder 1
P0301 00 [237] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 124031 km
Date: 2021.01.03
Time: 14:36:47
Engine RPM: 2256.50 /min
Vehicle speed: 53 km/h
Mean injection quantity: 20.03 mg/stroke
Mass airflow sensor 1 bank 1 airflow: raw value: 692.6 mg/stroke
Fuel temperature sensor 1: B1: raw value: 37.1 °C
O2 sens. 1 bank 1 upstrm oxi cat: raw value: 2.4526
27353 - Cylinder 3
P0303 00 [237] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 124031 km
Date: 2021.01.03
Time: 14:36:47
27352 - Cylinder 4
P0304 00 [237] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 124031 km
Date: 2021.01.03
Time: 14:36:47
27354 - Cylinder 2
P0302 00 [237] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 124031 km
Date: 2021.01.03
Time: 14:36:47
5242 - Fuel Pressure Sensor (G247)
P0191 00 [229] - Implausible Signal
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 124035 km
Date: 2021.01.03
Time: 14:41:18
Voltage terminal 30: 12.520 V
Engine status: COENG_FINISH
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 5
5260 - Sensor 1 for Exhaust Temp Bank 1 (G235)
P0544 00 [172] - Circuit Malfunction
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 124151 km
Date: 2021.01.03
Time: 16:19:56
Engine RPM: 936.00 /min
Normed load value: 21.2 %
Turbocharger 1 turbine output: temp. sensor 1: B1: raw value: 150.0 °C
Particulate filter input: temp. sensor 1: bank 1: raw value: 152.5 °C
Particulate filter output: temp. sensor 1: bank 1: raw value: 194.2 °C
Readiness: 1 4 0 0 0
Thanks, Cortlandt
Here's the data:
www.Ross-Tech.com
Revision: 8AH20---
19 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 124025 km
Date: 2021.01.03
Time: 14:31:29
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 123933 km
Date: 2021.01.03
Time: 12:45:49
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 124022 km
Date: 2021.01.03
Time: 14:29:06
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 123901 km
Date: 2020.12.20
Time: 15:22:59
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 124022 km
Date: 2021.01.03
Time: 14:29:29
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 124026 km
Date: 2021.01.03
Time: 14:31:30
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 123901 km
Date: 2020.12.20
Time: 15:22:58
P0300 00 [237] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 124030 km
Date: 2021.01.03
Time: 14:35:50
27355 - Cylinder 1
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 124031 km
Date: 2021.01.03
Time: 14:36:47
27353 - Cylinder 3
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 124031 km
Date: 2021.01.03
Time: 14:36:47
27352 - Cylinder 4
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 124031 km
Date: 2021.01.03
Time: 14:36:47
27354 - Cylinder 2
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 124031 km
Date: 2021.01.03
Time: 14:36:47
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 124035 km
Date: 2021.01.03
Time: 14:41:18
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 124151 km
Date: 2021.01.03
Time: 16:19:56
