I've been trying to research this oil leak of mine, narrowed it down to a few things.
I have a 2015 Passat tdi with 76k miles. Over the last 15k miles, I noticed I've been losing some oil. Began with about a quart the first 10k, then got worse lately with a quart during the last 5k. Originally I thought that I was having a oil pan leak because the foam under the pan was soaked and I really don't make that much of a mess when I do my oil changes. Anyways took the foam off awhile back, and what do you know, no oil from the pan. Yesterday, I got back under there and noticed two areas. Oil/dirt residue around the serpentine belt (hmmm crankshaft/camshaft seals?) and the back side of the transmission.
Pulley Residue:
Transmission Residue:
Could the oil be running down from the front seals, all the way to the back?
Pulley Residue:
