Luksta
New to me 2013 Touareg TDI Executive is in the Shop, had EGR & oil cooler replaced...now temp gauge reading high. As described by Tech at local VW dealership who replaced said components. He seems pretty competent but since he gave me details on the issue, my brain is troubleshooting.
Starts up and runs at 200 degrees steady, after about 30 minutes at idle, gauge quickly races to 280, but actual engine temp doesn’t rise. Troubleshooting advised to replace Temp sensor. When temp sensor, which was replaced by VW tech with VW OEM part, is disconnected, then gauge immediately reads 200 degrees again.
Any similar experiences, tips or insight greatly appreciated. Does anyone have access to full wiring diagram, what else is in that ground loop?
