Phathektor
Hello Diesel Heads,
Today I am installing Smoke Side markers I got from UROTuning. The install is fairly simple.
Tools Needed:
T-20
T-handle or rachet.
Simple Unboxing Pics
What I did: I started by working on the Driver side.
I first turn the wheel full lock towards the passenger side.
I located the inner fender liner bolts. I believe they are T-20, You will see 3 of them. There is a fourth one under the fender but you dont need to take it off.
Once you pull the inner fender liner out you will see the side maker tab. Just press on the tab and push out. The side marker will come out easily. Take out the light bulb socket.
Putting it back together is the same in reverse.
Install Pics:
Tools Needed:
T-20
T-handle or rachet.
Install Pics:
