2010 Jetta TDI Radio stopped working suddenly
Clarence
china
A5
Some aftermarket shop also provide such stereo radios with the same style like OEM ONE, the advantages are that they usually integrates many other userful features and the total price is low such as the seicane S30901 2005-2013 Jetta , seicane S301040 for 2012-2015 Jetta.
ColumbusTDI
Columbus, MN, USA
2010 Sportwagen TDI; 2019 Touareg TDI
Replaced my dead Premium 8 with RNS-315. Good decision!!
I just wanted to come back and update that Barry sent me a new system and I installed it in just a few minutes. Works great so far. Thanks Barry!
Same here. I bought a RNS-315 system to replace the dead Premium 8 system in my 2010 JPW TDI. I traded the 6-disc CD changer for navigation Removing the original system and installing the new would have taken only 5 minutes (10 max) IF I hadn't chosen to enable the RNS-315 Bluetooth features.
I gave up trying to find a clear path from the dash under the carpet to the Bluetooth connector under the front passenger seat. I gave up fishing the wire under the carpeting and just ran it behind the plastic on the center tunnel and out by the sear rail. I could have completed the swap in 10 minutes if I just ran the wire behind the plastic trim in the first place.
Thank you, Barry, for concise instructions too.
amanjeet
Canada
2011 2.5L Highline Jetta, 2014 1.8 TSI Passat
My Betta's horn and radio stopped working. When I turn my seat warmer on my screen starts flickering. I don't know if this means if my radio is done or if I have a wiring issue.
bjtp27
Saint Louis, MO
2011 Jetta Sportwagen TDI
Another dead radio here. 2011 Sportwagen with 66,000 miles.
After the radio died and the weather got colder, I was having a hard time starting the car on cold mornings. Then it wouldn't start at all (around 20 deg F) and I got a new battery which I thought would fix the problem completely. It did help but its still been struggling on cold mornings. I noticed earlier in this thread how the defective radios may be drawing on the battery? I'm hoping to go with the Barry fix, but I'm hoping I don't continue to have trouble starting the car. I did read some more info on this site about cycling the glow valves to help with starting on cold mornings and that did seem to help today.
ndenni01
Louisiana
2010 VW Jetta TDI, 2004 VW Beetle GLS TDI
2010 Jetta TDI. Dead Delphi 28242585 at 124,000 miles. Contacted BarryT82 and Crutchfield.com for options. I'll post back with what I choose and how it works out.
mauric6943
Long Beach & SEH
'10 VW Sportwagen
'10 JSW TDI radio almost dead
You can add me to the list :( although my issue is slightly different than what others have described
2010 JSW TDI
Turned the car on while driving to dinner and radio was dead. After about 5 min radio came on. After dinner same thing, dead initially and back on after 5-10 minutes. When i got home I turned the car off but hit the power button and the radio stayed on but the screen flickered a bit.
Check the fuses and everything looks good.
Pulled the radio out the dash and connections look good.
Since my radio isn't dead-dead (at least not yet) do you think my issue is the same as everyone else?
BarryT82, still selling?
amclane
SEVT
10 Jetta
BarryT82 gives great service!
I have a 2010 Jetta TDI with radio 1K0 035 180 AC and after 169000 miles it quit... found this thread. I posted a PM to BarryT82 and 4 days later I have received from him and installed a newer version of the same radio that works perfectly! Thank you, sir!
maybe368
Phoenix
Happily none
I have an rns-315 and gps antenna that I bought from Barry. I removed it from my Beetle because it is going back soon. I am out of town for a bit, but it is available for sale, it has the backup camera attachment also, although I left the camera as to not leave a hole in the bumper. It is in like new condition and I reset it to factory defaults before I removed it. First 200 bucks takes it, but I won't be able to ship for a couple of weeks...Mark P.S. The oem backup camera is available on eBay for around 90 bucks...
kooyajerms
grocery getter
Pomona, Southern California
Our JSW had a bad battery that most likely killed our RNS315 with all the low voltage issues. Splash screen comes on randomly and shuts off. None of the internet tricks ever worked to hard reset it or shut it off.
101k miles.
Went for an RCD510 AF unit for the HD tuner instead of keeping the Nav options. We will see if my ebay purchase works out.
dieseldreamin
Fort Wayne IN
'10 JSW TDI
There she goes
Radi went out on my 2010 jsw yesterday, comes on after the cars running for 5 minutes going to go have the battery tested, if that's not the problem then going on Craigslist or online retailer.
maybe368
Phoenix
Happily none
If you can wait a week or so, I have an RNS-315 for sale. It has the back-up camera port and all you would need is the camera, about a 100 bucks on eBay for an OEM VW one. I am in Mexico for a bit more, but I plan to list it on this site when I get back...Mark
respond2us
Tulsa, Oklahoma
Jetta, 99.5, Custom - Funky Green. 99 NB TDI, 06 Jetta TDI
Mine died this week. '10 JSW with the touchscreen radio, no nav. I did have it outside the garage for awhile so maybe the heat has something to do with it? Just checking this thread to see if there's a fix. Looks like the "fix" might be getting with BarryT82. ha!
K8gr8
DC Metro
2010 Jetta
Another one bites the dust
Radio stopped working this week in my 2010 TDI. 'Premium' 8 radio. (I guess 'premium' means that it'll last 50K miles, bc that's how many I have on the car.)
Researched tech bulletins. None. Looked here, tried all the easy fixes. Seems like replacing it myself isn't too difficult. Dealer assessment and replacement @ $600-800 is NOT going to happen.
My concerns: (a) how will I know if the aftermarket radio I purchase will have same phone bluetooth functions and (b) there's no guarantee that this won't happen again, right? and (c) is the current non-operable radio draining my battery? Should I disconnect it now to prevent that? Will removing the fuse prevent this?
Thanks for advice.
-k-
(just a car curious middle-aged woman trying to fix it myself)
jetlagmech
Toledo, WA
2010 jetta
(a) that is why I went with getting a used newer model. and also hooking up the wires on a aftermarket can be a nightmare instead of just plugging it in. (b) again I did mine with a newer model that has seemed more reliable. our car came with model number XXXXXX-AC I installed a model XXXXXX-AE. Mine didn't have Nav or backup camera. (c) Depends how the radio failed. some have had the dead radio drawing power running the battery down, but most have not. There are 2 power sources for the radio. a switched wire, (on and off with key) and a hot wire (power all the time) I pulled my radio out and unplugged it waiting for the newer one just to be sure.
replacing it myself was easy. The screws have a star tip type head. If you have a replaceable tip screwdriver that came with a rack of tips, you have them.
Good Luck
respond2us
Tulsa, Oklahoma
Good for you doing it yourself! On the aftermarket option, that install would be more complex than OEM. However, there is a product Crutchfield sells calls an idatalink maestro that will retain your steering wheel controls. If you want simple, get a newer oem unit that has a better track record than these high failure radios.
I'm doing aftermarket because I wanted apple CarPlay and a back up camera, but if you've never installed an aftermarket stereo, it can be pretty crazy.
maybe368
Phoenix
Happily none
Thanks for advice.
-k-
I have an original VW RNS-315 with nav, bluetooth and backup camera. I bought it from a member here on this forum and installed it in my '14 Beetle,mostly for the backup camera.I sold the bug back to VW but I reinstalled the original radio.I will take 175 Dollars plus shipping from 85007, or best reasonable offer. It is in like new condition...Mark PM me if interested...
K8gr8
DC Metro
2010 Jetta
Thanks guys!
Where do I find a newer OEM unit? How will I know if Mark's radio offer below will work for me?
-k-
maybe368
Phoenix
Happily none
mrgt
Manitoba
2006 Jetta TDI
I had mine die , 2011 sportswagen tdi. I have the 1K0 035 180AC. Phone still connects but radio is completely dead. I found in a junkyard a 1K0 035 188H. I think from what i read it should work. i got the code from the VW dealership. anyone know for certain if it will work?
Jack Diesel
New Jersey
2011 VW Jetta
2011 Jetta TDI, 135,000 Miles, just died. AM/FM/SAT 6 disc changer. Not sure if I want a aftermarket or try to see if anyone is selling one around here. Definitely not going to dealer after reading what you guys said.
jetlagmech
Toledo, WA
2010 jetta
Hope no CD's in it when it died. I had to go buy another set of star tips to disassemble mine to get the CD's out. didn't have a tip small enough on my set for the inner pieces. took a while and parts all over the tabletop. At least it was a slow day at work so I got paid to do it. guys were all laughing at my mess.
Fixmy59bug
Henderson, NV
2015 Passat TDI SE
Yes, it will work.
Jack Diesel
New Jersey
2011 VW Jetta
Does anyone know what # the fuses are for the radio for a 2011 Jetta? I read in this thread #57 & #8. It drained my battery already and I need to pull them so it doesn’t happen again before I change it out
jettamylove
Vancouver Island
Jetta 2010
Help, my radio died and now my battery keeps running out of juice. Doing the buy back in Sept so just want to keep battery charged. Does taking out the fuses work for the battery drainage problem? I can't believe this is so common, grrrrrr!
Fixmy59bug
Henderson, NV
2015 Passat TDI SE
Should just be able to pull the fuse on the back of the radio.
Disconnect the quad lock connector, and remove the 10amp fuse
jonnywater
Golden, CO
Jetta
This may not work for all BUT...
My radio in my 2002 Jetta had died twice, both followed by a dead battery. I inspected the battery connection and there was corrosion on the battery. Both times i cleaned the connection and the car cranked up like normal and the radio was fine.
Hydesmith
Winnipeg, MB
2011 Sportwagen (Highline)
Another dead radio
2011 TDI Sportwagen - Radio and horn not working.
Radio suddenly cut out while we were driving. Similar symptoms as others, in that the bluetooth pairs, but no sound, no lights. Other controls on steering wheel work fine.
Rear seat passenger says she occasionally hears (with younger ears) a brief sound from the speakers, although I could not confirm that from my driver position.
This radio quit happened just a few days after a TDI-specialist shop was diagnosing my horn not working, and traced the probable cause for that horn to an aftermarket wiring harness for a previous owner's remote car starter, which she later had disconnected. I'm rescheduled for that repair next week.
Notable perhaps is that the aforementioned previous owner also complained about pesky battery power loss when parked. The removal of the remote starter unit was part of her attempts to remove the battery drain. I have not experienced this, but my battery is new.
I'll have that harness removed net week and hope it reignites both the horn function and the radio. I'm counting on them to solve this.
If the radio is faulty, and they have no replacement, I'm guessing that an aftermarket unit may be a better solution, so I would value any recommendations on ones that pair well with the existing car's systems, including dashboard display and steering wheel controls.
Q: Is adding a backup camera complex? Is the wiring already there?
