Thanks, a big hug...great pictures to help meMBoni said:Hi Babe,
Yep, you'll have to remove the front bumper in order to access the bottom bolt on the headlight assembly, and there are a surprisingly large number of screws (torx head) you need to locate, including a few inside the wheel well.
There is a good DIY guide with pictures here:
http://forums.jettamkv.com/viewtopic.php?f=51&t=2109
Technically, you are removing just a plastic bumper cover, the steel(?) bumper remains firmly attached to the car. I'd think that even the skinniest waif should be able to handle it, as long as she was old enough to drive.Babe said:do you think a girl can do it. Is the bumper heavy.
ThanksMBoni said:Technically, you are removing just a plastic bumper cover, the steel(?) bumper remains firmly attached to the car. I'd think that even the skinniest waif should be able to handle it, as long as she was old enough to drive.
That said, you might want a 2ND set of hands to help you. I did the job solo, but had to jump back and forth between the left and right in order to re-install the bumper cover. Pushing one side into place would end up getting the other side off, so it took a few extra attempts. And it's always good to have another set of eyes looking at the instructions, making sure you don't miss a step. No need for a mechanic or a lumberjack, but someone else who can read and follow instructions might be handy. But if you can't find someone, don't sweat it, just take your time and have fun.
I don't recall any locking tabs, just lots of torx screws. Getting the headlights in and out required a bit of a twisting movement to clear some of the supports, but once you find the right angle it's not bad.Babe said:after all the bolt and screws and clips are off. does it snap on with tabs or just an easy pull and its off?
Thank you can't waitMBoni said:I don't recall any locking tabs, just lots of torx screws. Getting the headlights in and out required a bit of a twisting movement to clear some of the supports, but once you find the right angle it's not bad.
