Q-Ship
You've got mail.
A few questions:Just had mine done and the dealer couldn't have been nicer. VOA picked up the tab, and given our location, the dealer is now keeping the kits in stock. I am trying to find out if this is a standard feature on EU VWs. BTW, I had a Mk VI Jetta (2011) as a loaner. Yech!!. I heard it had been decontented but going beck to a 1950s trunk hinge design is a little much. And talk about body roll - I thought I was driving my grandmothers '72 Bonneville!!
Had the "no crank" failure mode and had the U-Boat towed to the dealer. I was lucky I didn't bend a conrod! They suspected it was the intercooler problem right away and called later to say that they had emptied a significant amount of water our of it. Nothing else was required. I put a lot of miles on the vehicle and thus it was out of warranty. I think someone at VOA figured out that charging a customer $1200+ to fix an obvious design flaw was not good business.A few questions:
1. Did the dealer demand that you have the issue "reproduced" prior to them filing a claim for you against the TSB?
2. Is the car still under warranty (3/36 B2B or 5/60 PT)?
Thanks!
Since my last visit to the dealer noted above, I got a call from VW USA today asking me if my cold start issue has been resolved. I was really surprised that they called. The lady asked me what they did for my problem. I told her that they couldn't replicate the problem and found no error code on the computer, then sent me home.
She said she will call back on Friday, 1/27/12, because she need to find out what the dealer did to troubleshoot.
Further, I told her that I suspected the intercooler iced up because a lot of online people are having the same issue and there is supposed to be a retrofit kit to fix the problem. She said that there is such a kit, but it won't work on the "newer" TDIs - I'm assuming she's referring to the 2011 and up.
She said she will call back and most likely will want me to bring the car back for further diagnostics. I told her I'm glad she called, she replied: because we do care if you are having issues.
At this point, it sounds like to me that VW probably thought they've solved the cold start issue with some kind of design change to the 2011, and got very interested once they saw my problem reported to the dealer. Maybe they will send their tech to the dealer?
Will keep you guys posted.
Not sure what the dealership is calling the "pumps retention valve" The only retention valve I know of is in the return line from the injectors. It purpose is to hold/maintain pressure of the injectors bleed off to let the injectors function properly. I would not think they would be talking about any hpfp parts. As far as I know they do not replace individual parts of a hpfp.Update to my post above.
Finally brought my car back to the dealer for further troubleshooting per VWoA's request. With the VWoA tech on the call with the dealer's tech, they inspected the high pressure fuel pump for metal debris, checked fuel pressure, and checked the retention valve in the fuel pump - everything ok. Also, found no error code on ECU. They probably suspect a fuel pump failure or some sort. Not uncommon with these TDIs.
Without finding any signs of problem (or at least they said they found nothing), they are going to replace the fuel pump's retention valve and install the intercooler kit. Ordered the parts and will call me when it comes in. I was told it could take a few weeks.
One thing they did not mention is the condition of the intercooler and the hoses connected to it. No mention of any water in the hoses.
Does anyone know why they would want to change the retention valve???
The dealership only does what VW Tech tells them to do when its under warranty. Maybe ask the dealership what codes it was throwing? (if any) I have not heard here of anyone getting the fuel retention valve replaced before as a fix for a problem. Just have to wait and see if it fixes the problem. As I stated before the retention valve holds bleed off fuel pressure from the injectors so they will function properly. I'm not sure if that bleed off pressure can be read anyway. Maybe the injection pressures are reading out of spec. Just a guess on my part.I think that's it. I was probably mistaken by with their explanation over the phone. Have an idea why they would want to change that out?
Mine is also on order at VW Coleman of Bridgewater, NS since about December. I didn't have the problem again so I forgot a bit about the kit. I will ask them again in June. I will be in Germany in April-May and will try to ask a dealer about the kit and its replacement.My intercooler kit is on order. Been waiting for over a month. My service adviser says this kit is a newer version, which will replace the entire intercooler, not just adding a valve. Will keep you guys posted.
How long is the warranty? My Golf wagon (aka JSW) is a June 2010.keep the pressure on! or you may be out of warranty next winter and the dealer will just shrug
MotoWPK, I agree with your assessment. Sadly, contrary to what thanatos asserts in the previous post, it isn't something that has "hit thousands of us."...maybe not even hundreds. The past mild winter has also probably delayed the arrival of this issue for those of us that are on the "freeze line."
