artificer
Just wanted to post about the bad EGR in my Jetta. Over the last year it was losing power and smoking more. Mileage went down as well. I was told it was probably a boost line leak, but that wasn't the cause. Ended up being a stuck EGR valve. At the end the engine hardly started, would knock when revved, and made a big cloud of black smoke.
I decided to replace the EGR instead of trying to clean it. (230K on the engine) Engine is running better than it has for the last year. I'll eventually clean the old EGR, and see if it still works. If it does, I'll have a spare to use.
The car has a stage 1 Malone tune with dynamic EGR. Bigger injectors were installed during the head replacement. (pump bolt came loose and took out the timing belt at 183k) The dynamic EGR tune was used to hopefully make the 2nd replacement EGR cooler last for the rest of the cars life.
Hope this post can help someone diagnose their problem in the future.
Michael
Michael
