DreadtimI
Is there a block heater and is it recommended for 2003 tsi jetta? I live at 9000 ft in the southern rockies, often -15 in the morning and I don't wwant to fry the turbo --is a block heater recommended ?
I was thinking of doing that here, in Alaska.ymz said:For extreme cold, you could move to a 0W-40 oil that meets the other standards
Alaska ??? Well, that's just like Canada... except for the health system...FL2AK-tdi said:I was thinking of doing that here, in Alaska...What do you think?
__. When you say "blockheater is useless", are you referring to the stick-on heater that VW sells for adhering to the bottom of the oil pan? If so, yes, it's completely agreed that it's very close to useless. But if I were in that environment, I think that I'd have one in addition to the tdi-heater in the coolant line. While the coolant heater would do an excellent job of warming the entire engine and thus the oil would be heated -- especially in the areas of the engine with the water jacket -- I would want to heat the oil in the sump as much as possible. Probably "over the top", but it's how I'd prefer. Get as much heat into that engine as possible.peteman said:Suprised no one mentioned the tdi heater. I use one wheenver it dips below -10. Today it's -20 and when I start my car it will blow heat out of the vents and be at operating temp. There is no need to run the glow plugs. www.tdiheater.com or www.frostheater.com. Blockheater is useless.
Someone did mention the TDI Heater... in the 2nd post.peteman said:Suprised no one mentioned the tdi heater. I use one wheenver it dips below -10. Today it's -20 and when I start my car it will blow heat out of the vents and be at operating temp. There is no need to run the glow plugs. www.tdiheater.com or www.frostheater.com. Blockheater is useless.
Touché.ymz said:Alaska ??? Well, that's just like Canada... except for the health system...
Yuri.
Where do you live? If near me, I can help you install a TDI heater. I've done several and got it down to about 30 minutes of work.DreadtimI said:Is there a block heater and is it recommended for 2003 tsi jetta? I live at 9000 ft in the southern rockies, often -15 in the morning and I don't wwant to fry the turbo --is a block heater recommended ?
__. That's what I would have guessed. *Every* degree that the oil starts out warmer is better (OK, a slight exageration for emphasis but you know what I mean -- warm oil is better than cold oil).jasonTDI said:Yep, the oil haning out in the pan dosen't get too warm. Maybe 20F warmer than ambient. I've felt the pan and pulled the dipstick to feel the oil, not to warm.
__. Interesting experiences. The whole idea of "stickon" bothers me anyway. If you have a cold oil pan and a cold heater plate and you hit the juice, what happens? First the heater warms up and expands while the pan stays cold -- isn't that going to give you differential heating and expansion and pull at whatever adhesive is supposed to be holding that thing on? And you're fighting gravity all the time anyway -- that heater plate is just hanging on the bottom of the pan by the adhesive. That's one of the worst uses for an adhesive around. No wonder it fails.Be careful to inspect that oil pan heater a LOT! Make sure you CLEAN the HECK out of the pan so the adheasive REALLY sticks and I'd still check it monthly at a minimum since I have replaced at least 5 belly pans in the past 2 years that MELTED due to the pad coming off. Huge fire risk.
If you wanted to use an adhesive, 3M makes a product called PRC. It's an aviation sealant. There are about 10 different varieties. All of them wll expand and contract with temperature changes-severe and rapid changes. An aircraft can go from 100 deg F sitting on the gate at Tampa International in August, take off and within 10 mins be above 12k ft altitude-where the tempertures start dropping off toward -35F at 30k ft.mrGutWrench said:[...]isn't that going to give you differential heating and expansion and pull at whatever adhesive is supposed to be holding that thing on? And you're fighting gravity all the time anyway -- that heater plate is just hanging on the bottom of the pan by the adhesive. That's one of the worst uses for an adhesive around. No wonder it fails.
__. If I had to use one, I'd rig up some kind of helper strap or bracket (s) to hold it.
