Wagon man
I have a set of stock injectors from my jetta. They are from an automatic transmission Jetta that was upgraded to larger injectors. I have some photos if you are interested just email me at TLeggemann@msn.com The jetta had 25,000 miles when I swapped them out. If you are interested and you are emailing me please put TDI Injectors in subject line.
Thanks and hope to hear from you all.
Thomas
Injectors from my 2003 jetta wagon automatic
$150.00 SOLD
Lights ON EBAY:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=014&sspagename=STRK%3AMESE%3AIT&viewitem=&item=330265122674&rd=1
SOLD
Wires and Grommets that come with head lights "SEE EBAY"
$EBAY$
SOLD
Injector wrench 17 mm / Diesel TDI Injection Line Wrench 17mm
$32.00 SOLD
New Boost Gauge / A pillar mount / hose / wires / with back light / installation instructions
$53.00 SOLD
Fuel line cover / stone shield: $7.00 SOLD
Left Hand side "drivers side mirror": $9.00
OEM Light Switch: $5.00 SOLD
OEM used plastic belly pan / plastic cover shield over oil pan
$22.00 SOLD
Side brace for plastic cover shield / Side Engine Cover Plates / Both Left and Right side
$20.00 SOLD
New Vented Wheel Well cover for better air flow over inter-cooler / Vented Fender Liner-Right Side
$32.00 SOLD
Works great. I took out to repair because driver’s side headlight would not come back on "passenger side fine". Found that the wire is loose “main light on drivers”. This should be a quick fix for someone. I lost the car in a wreck shortly after removing them and have no way of testing to see if it is fix, so I left it the way it was. I can send a photo of what needs to be done, if there are any questions. I will be listing other things for the TDI Jetta Wagon that I will no longer be needing. It comes with all bulbs and some spare bulbs.
Bulb: 194
Bulb: 7505 ( PY21W )
Bulb: H4
Bulb: H3
2 wires 000 979 134
4 wires 000 979 133
2 grommets 357 972 741B
4 grommets 357-972-741 / 51797
5 green grommets
2 grommets part # 357972741A Dealer # 409145
Bulb: W0177512
Shipping is extra and will be the actual cost to me.
Thomas
$150.00 SOLD
Lights ON EBAY:
SOLD
$EBAY$
SOLD
$32.00 SOLD
$53.00 SOLD
$22.00 SOLD
$20.00 SOLD
$32.00 SOLD
99-05 VW JETTA BORA STYLE Silver HEADLIGHTS W/ FOG
This BORA STYLE headlights is made by DEPO
COMPLETE 2PC, LEFT & RIGHT SIDES.
Grommets / Wires / BulbsWorks great. I took out to repair because driver’s side headlight would not come back on "passenger side fine". Found that the wire is loose “main light on drivers”. This should be a quick fix for someone. I lost the car in a wreck shortly after removing them and have no way of testing to see if it is fix, so I left it the way it was. I can send a photo of what needs to be done, if there are any questions. I will be listing other things for the TDI Jetta Wagon that I will no longer be needing. It comes with all bulbs and some spare bulbs.
Bulb: 194
Bulb: H4
Bulb: H3
2 wires 000 979 134
4 wires 000 979 133
5 green grommets
Bulb: W0177512
