Rickstah
Hi all, I recently fixed a problem with an aftermarket stereo head going into a Monsoon system, and part of the fix was doing some rewiring in the fuse panel. I set fuse 32 (monsoon amp) to switched power, and ran hot power to the stereo via another hot fuse location.
The stereo works fine, however I am now noticing that sometimes when I turn off the ignition switch, the motor keeps running for a few moments before it turns off, and a single long beep happens, usually about the time I remove the key, but not always. I want to say it is a warning about the engine running for a moment with the ignition off, but I have no knowledge there is some diag that would do that, but am starting to look.
Is it possible there was more going on with fuse 32 than I thought? The only changes made are fuse 32 is now switched power, and another fuse, I forget which, which is hot, has a tap from it to the stereo providing memory voltage. I saw nothing that was loosened while I had the fuse block pulled out the side of the dash, and it doesn't always beep, nor does the engine always run for a split second longer than before when ignition was switched off. Thanks.
