eddie_1
- Joined
- Dec 27, 2004
- TDI
- Jetta Wagon 2003 TDI tuned to 170HP, A6 Wagon 2008 TDI 2.7L tuned to 340HP
helped someone who came to Europe (Switzerland) for a year from Canada looking for a car with several kids. Just wanted to share a profile of what is kind of representative and available and what I found and what work was needed on this particular PD built in Portugal.
Car looked good off the lot in Swiss and I ran VCDS on it for codes and the boost. It was overboosting a bit but engine sounded great with 300K Kms. Of course I was unable to drop the underpan there but did the deal anyway for about $2000. Contrary to the PD injector wiring and PD injector issues most report it had other issues after 300,000 Kms:
- It had a weird issue where the Head Gasket leaked coolant into combustion at high loads with engine overheating. Occured first time when trying to climb Swiss mountains. For flat, part load driving no problem. Drove the vehicle to Germany for the work. Too expensive in Swiss. Supplied Head gasket/bolts and timing belt kit for €200 and shop charged €700 labor.
- AC compressor was shot. Pulley freezing meant on the brink of ripping the belt as well. replaced it self for €40 used. (Germany is parts/used parts heaven)
- AC Condensor then had a hole. Not fixed yet.
- Clutch Master Cylinder leaking. Replaced self for €130 (Had to buy the part in France else €70 in Germany)
- Driverside half axle inner CV boot ripped. Not yet fixed.
- Clutch thow out bearing chirping at cold start. Not yet fixed.
In any case with the work done it is humming really nice up and down the alps. As I said no PD injector and wiring issues.
