borachris
I'm considering putting a 2litre 16valve engine(probably a BMN) into my MK4 Bora which is currently an ASZ 130PD.
Main question at the moment is which ECU should I use? The 15 off a MK4 or 16 off the MK5?
What benefits or drawbacks am I likely to encounter from either?
I know I would have issues with the lack of DPF if using the edc16.
Anything else that I should take into consideration when deciding?
