markd89
Hi All,
This is in my 78 Bus, but please think of it as a 97 Passat TDI ;-)
I have a Malone stage 2-ish tune which is good for 17-18 psi of boost. I'm running the stock IP and turbo. I have a somewhat extreme A2W intercooler setup, but that's another story. Everything else is pretty much stock.
Symptoms:
Recently, I have been seeing less boost than I used to. The engine is slower to boost and peak is less than before.
Peak used to be 17-18 psi now 10-ish.
Freeway cruising normal used to be about 10-12 psi, now it's 6 or 7 psi.
If I let off the accelerator at about 70 mph, I used to maintain ~4 psi of boost, now it's zero.
The bus runs pretty well, it's just has symptoms of low boost: less peppy, more smoke, higher EGT.
I checked VCDS and do not see anything jumping out at me...
There are two faults:
00560 Exhaust Gas Recirculation System, 17-10 Control Different Intermittent (I have the EGR vacuum tube disconnected)
01050 Glow Plug Monitoring 35-00 (I have a bad glow plug)
Other VCDS stuff:
03 MAF Spec: 645 Actual: 445 EGR: 19.9%
04 Injection Spec: .9 BTDC Actual: 1.3 BTDC
011 MAP Spec: 1101 Actual: 969
013 Idle Speed Cyl 1 -.38 Cyl 2 -.07 Cyl 3 -.02
Could the MAF be at fault?
I have checked for boost leaks and haven't found any. I have not pressurized the intake as I don't have a compressor right now.
The stock turbo has appx 170K miles on it. I don't hear any noises but I'm not sure I would notice over the noise of the engine.
Any suggestions on what to check and what the problem might be?
All help much appreciated!!
Thanks,
Mark
Symptoms:
Other VCDS stuff:
Thanks,
Mark
