G60'rado
- Joined
- Oct 23, 2013
- Location
- Calgary, Alberta
- TDI
- 1990 Corrado G60, Donor Mk4 Jetta, Donor 1994 Corrado VR6
Had a nice surprise in my CTN when I opened it up.
The spider gears have started to pit, so they are done. Going to replace the carrier bearings since I'm in this deep anyways.
The ETKA says for this transmission, it uses the 02T498081B "assembly", it doesn't break down the individual parts.
Apparently it uses the same assembly as the later o2j. I can't find what years of o2j that might be a junkyard donor for some new gears.
Or, if any one has some good used ones, I'm in the market.
Thanks!
Thanks!
