I never planned to part ways with this car, it is amazing in every way. I have precious little passangers so opted for a newer TDI wagon for safety. It is California diesel title. I converted it from VR6 at 208K, it now has 236K. Ahu had 140k on it at conversion. All new VR6 clutch, timing belt, water pump, front axle and suspension parts as needed at time of conversion. Has 12mm IP, pulls good. All stock electronic functions work. A/C hooked up but never charged. Only non functioning item is cruise control, did not bother hooking it up although wiring is there and labelled. Tach is not modified for 4cyl, so is not accurate. MFA works. The conversion is as if it were stock, not a hack job. It has b4 front seat belt conversion. Has the mk3 cat too.
Gets 45+ MPG. Never had a single issue with it. I daily drove it for a number of years, and have taken it on long trips.
I have the IC setup from a b4. I have several parts as spares like hood, front bumper cover, front spoiler grill assy. It has monster mats from a mk6 tdi.
It is an honest original car with TDI conversion.
$5,500
Located at 95614
$5,500
Located at 95614
