Sputterputz
Just got ready for my first drive in the shops alh tdi kubvan. However. I am getting a map sensor altitude implausible corelation code.
Checked measuring blocks 10/11 and the baro matches the manifold pressure. Requested vs actual matches.
150hp kit from kerma zero mile rebuilt long block s7 turbo. 3bAr MAP.
anything else I should check? Map wires show no ohm issues from ecu to connector. Both ends are clean. Wires are soldered were they were in the factory t10 connectors.
