hey guys new here, 06 brm 145k, complete egr delete, stock exhaust, malone stage 1, new cam the works..
issue im having is car is constantly trying to build boost, start driving in 1st ever so slightly giving it gas the boost climbs to about 15-20 psi before it falls to roughly 5 and car accelerates better, same thing in every other gear.. on the highway if you give it throttle just a bit the boost climbs and holds at 15 instantly, give it more throttle and itll fall to 5 and will act normal untill you decel and get back on the gas
vacuum tested the actuator and n75 all seem to function correctly, im leaning towards stuck veins in the turbo not letting the car precisely adjust the pressure, thoughts before i blow money on a pd140 in hopes of fixing this?
